Ir para o conteúdo principal
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
20 Perguntas Visualizar todos
Is this a good alternative to an iOpener?
The kit I just ordered to change the battery to my XS Max doesn’t come with an iOpener. I can’t find it on Amazon by itself but there’s one on here by itself that I may buy. I was just wondering if I heated up a wet paper towel in the microwave, placed the warm paper towel in a zip lock bag and sealed it would that be a good alternative to an iOpener? (Or even just a warm regular towel inside a zip lock bag)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Frankly I would just use a hair dryer or heat gun (variable temp).
A wet paper towel is risky! The water could sneak in! The other factor is it doesn’t have enough heat mass.
Esta resposta foi útil?
Pontuação 4
2 comentários:
My hair dryer does an amazing job at high! It burns me.
por
Sounds like you need a cooler hair drier ;-}
por
For difficult things to heat up safely, I wrap therm in a clean cup towel, turn my toaster oven on to bake and sit them on top for a couple of hours.
Pontuação 2
Adicionar a sua resposta
TMay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 1,129
