Ir para o conteúdo principal
Is display data wire the same in model A1260 early 2008-late 2008?
halo ifixers!!
i have an mac book 4,1 15"inch early 208, and the display data wire looks defekt, i would ike to change it myself, but want to know first if the wire is the same in the model of early 2008 that in the lat 2008.
i read in the past, that one model has 16pin connector and the other 21pin, but now i cant find it anymore
thanks in advance for any answer!
/v
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Those cables are very different as the Late 2008 MBP was when they switched to the Unibody design.
Early 2008 MBP 15":
[produto vinculado ausente ou desativado: IF185-133]
Late 2008 MBP 15" Unibody:
MacBook Pro 15" Unibody LVDS Display Cable
Imagem de MacBook Pro 15" Unibody LVDS Display Cable
Produto
$19.99
Esta resposta foi útil?
Pontuação 2
3 comentários:
hey scott thanks a lot fot the great/fast info!
but one sort question, to really clarify myself:
-models MBP from early 2008 and late 2008 - same disp.data.wire
isnt it?
thanks in advace again!!
por
No the display cables are different. The late 2008 MBP is a Unibody and not of the same era of architecture as the early 2008 MBP. The entire video circuitry is different. That is why Scott provided you with the links to the 2 different LVDS/display.data.wire cables.
por
ok, great!
was my fault, i didnt get it in the right way
thanks a lot for claryfy it for my one more time
/v
por
Adicionar a sua resposta
animazon adiovisual lab será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,067
