Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
iPhone sound stuck on headphone
Replaced the battery in my iPhone SE (1st gen) using iFixIt’s kit and instructions, Speaker sound was fine until I plugged headphones in. Now sound is stuck going to the headphone jack even when the plug is out.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try a hard reset and clean out the headphone jack with iso… or just replace charging port if both fixes don’t work
Esta resposta foi útil?
Pontuação 0
2 comentários:
I think maybe the headphone jack may be off from the replacement procedure for the battery. What can the fix be for that?
por
@jshowalt Doesn't sound related... I've only seen it happen by glitch (Hard Restart), Bad/Damaged or clogged port and audio IC
por
Adicionar a sua resposta
James Showalter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 53
