Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Why is my screen showing black lines after replacing the battery?
Did I break my screen? After replacing my battery it looks like this, fickering black horizontal lines across the screen.
The phone still works but It doesn’t look good. I followed the guide perfectly and was extra careful with the connectors, I tried cleaning with contact cleaner the connectors and the ports but no success.
Anything else I can try before having to buy a new screen?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly with the iPhone 5 series like the 5, 5S, 5C, and 1st gen SE, they all suffer from this issue of the display getting damaged during battery replacement regardless of how careful you are while attempting the repair. All you need is a replacement screen assembly and you should be fine. As a repair shop, I even replace the battery without disconnecting it and I still sometimes have this issue.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I had no Idea it was that fragile! I did not read about that
por
Adicionar a sua resposta
ALBERTODELAVEGA será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 169
