runs for about 15 minutes then stalls?
My 07 jeep wrangler had the fuel pump replaced.
But runs for about 15 minutes then stalls?
I let it set for 5 minutes then it starts?
Will some times will run for a hour then stalls?
Esta é uma boa pergunta?
THANKS.
The shop said it's the crank sensor..
We will see if that's it ??
Esta resposta foi útil?
I think there might be multiple problems, but mostly it should just be timing or some issues with the computer, because i have a skoda superb that had it’s computer replaced because of a similar problem, or you can also try to check your wiring
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 57
Ao todo: 519
