Ir para o conteúdo principal
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is called the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
Can't access safe mode
Im trying to enter in safe mode, unfortunately i can't. After holding power button it doesn't beep as it suppose to be (one beep, another one beep and then two beep). It just turn on and ,the first beep (im still keep holding power button) but only turns off after almost 40seconds.
I did it again and the same thing happened... hold power button beep once and then turns off, also i did it a few more times but no beeps just the first one that sounds when you turn on your console.
Any help? :/
I forgot to say the ps3 works through Component/AV Cable, the hdmi is broken, after a storm just never work again. Can this be the problem? If i repair the hdmi will the safe mode work?
More info: When i hold power button it beeps one, then beeps twice (in tv i can see 480i ) then turns off, the second time i hold power button it just doesn’t beep i can hold the button probably 40sec and finally just turn off, if i try again it repeats (one beep, two beep and 480i in tv, then turns off) and thats all, like a loop.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi!
First things first:
When the red light is burning, press the power button and hold it. It will beep and turn on, keep your finger on the power button all way long, then it beeps again (video reset), still hold the power button, it will beep and it will turn off. When the red light is burning again take your finger from the power button. Then press the button again, hold your finger on it, it will beep and turn on again, still hold your finger on the button, it will beep again (video reset), still hold the power button, now it will beep twice, release power button and you should enter the safe mode!
Why do you want to enter safe mode? Due an error code or something? Anyway, you could also swap the harddrive and see if you can enter safe mode then. This should not be related to your broken HDMI port.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Tks for reply!
I'm trying to enter and install hfw.
I tried everything, watched a lot of tutorials, reading forums but nothing.
If it helps, here i left two videos so you (or everyone who is reading this) can see what is happening:
https://imgur.com/VZZ2Twa (the first try just beep two times, changes the resolution and turn off)
https://imgur.com/PzTDsw1 (second try, after the first, just turn on and off holding a while the button, i just cutted the video this is when it suppose to beep one, one again and then quickly twice)
Maybe in the second video looks like i still keep pressing the button but no i'm not.
Edit: i have the ps3 super slim 12gb version so even if i change the hard drive still the system just swap to intern flash memory
por
Hi!
After the 2 quickly beeps (release the power button), it should enter the safe mode.
Otherwise, you could restore everything and try again. What is the firmware version you are running?
Alright, nope won't do anything if you change the HDD indeed (if you have the one with flash memory onboard).
More people do experience it: Why can't I turn on safe mode in my ps3 super slim?
por
Adicionar a sua resposta
Aku será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 36
Ao todo: 3,947
