Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
30 Perguntas Visualizar todos
Possible to replace ipad mini 3 logic board with one from a mini 2?
Hi, i got an ipad mini 3 with touch problems, thinking i would replace the digitizer and be done with it. When replacing i noticed that the problem was with the fpc connector, and since I do not have the micro soldering capacities to deal with it, I was thinking if it was possible to replace the logic board with one from a mini 2, and use a mini 2 digitizer.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
No. You can't replace the logic board from one ipad to another unless they are the same model. Same thing with batteries, charging ports, etc.. why would apple want to make parts interchangeable. It's a bad business model if you want to sell new ones. Apple doesn't even make it easy to repair them.
Esta resposta foi útil?
Pontuação -1
Adicionar a sua resposta
ericsancha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 205
