Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
Is my display original?
I purchased a used iphone X with cracked glass and no Face ID. I planned to replace with an OEM screen and could have done w/o the Face ID. But now I realize that even the true tone is missing. So is my display already a replaced one or is original? How can I make out this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If face Id and true tone are both missing the screen has definitely been changed. Unfortunately face Id is not repairable unless you have the original parts. It sounds like they tore the cable to the proximity/floor sensor and earpiece speaker. It possibly to repair that if you can find someone with the skills. The front camera and those sensors are paired to the motherboard and if one is damaged or changed then you are out of luck. Unless you want to trade it for a refurbished one from apple and pay a few hundred dollars. But if you can find a repair shop that has the correct equipment you can get true tone back.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you for the answer. The rest of the phone is working well but even the auto brightness feature is missing and does not work. No 'replaced display' message in the settings as well. Just cracks on glass and dents around the earpiece area, can dropping the device cause all these issues?
por
It's a small possibility but the iPhone X will not show that the screen has been replaced. That feature if you want to call it that didn't start putting up that message until the iPhone XS.
por
Adicionar a sua resposta
Nitesh Rathod será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Ao todo: 117
