Ir para o conteúdo principal
iPhone 6s stuck apple logo, Restore ok..
Hi Friends, I have an curious problems with this iPhone 6s Plus: the phone power on but stuck on Apple logo. I have restore the phone, iTunes see it and ask the iCloud account connected, but I have only Apple logo on the iPhone. I tried to unplug, flat front cam, back cam, dock connector, replace battery and monitor but I have same problem. The phone don’t start and stuck on Apple logo..
Esta é uma boa pergunta?
Pontuação 0
6 comentários:
So it was a restore you did and not an update?
por
Exactly, two restore: 1 in dfu, 1 in recovery mode
por
Up, no one to give me advice
por
@modesto93 There is not much more you can do without the skills and equipment. I would remove the speaker amp IC and see if it boots.
por
Ok you can try, talk about the Big Audio IC 338S00105 chip?
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
modesto será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 85
