replaced battery but still does not start
replace the battery but still does not charge
Esta é uma boa pergunta?
@welch290 … no charging indicates 3 possible causes. no current from the ac adapter, bad/damaged cell battery or a bad/faulty charging ic chip on the motherboard. the only way to test these and diagnose properly is with a multimeter.
starting with the easiest, test the output of the ac adapter for voltage.
https://itp.nyu.edu/physcomp/lessons/ele...
next, check your batteries voltage.
https://www.youtube.com/watch?v=-MGQ0Ap_...
finally, open up the device and test for voltage from the charging port and then also the connector at the battery on the motherboard. to do this, youll want to have a schematic for the voltages that are supposed to be present, but not necessary to get an idea if its functional.
being that this is a mac, please post your model number a****?
you could also try to reset the pram and smc first if the battery was properly diagnosed.
https://support.apple.com/en-us/HT201295
with these tests, youll know exactly where the problem lies and how to correct it. you can use google/ youtube to learn how to do these tests, or post back here with any questions you may have.
Esta resposta foi útil?
Sadly the 13” & 15” Touch Bar both face the same issue which Louis goes over here A1707 Macbook Pro touchbar no power failed logic board PP3V3_G3H issue
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 103
@welch290 .... @danj .... sry guys, i may have mis-interpreted the fault here. is this an issue with no charging of the battery or the pc not turning on at all? (no power)
por jostewcrew
