Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Perguntas Visualizar todos
MacBook Pro Completely Dead
Last night, I turned off my Mac and didn’t charge for the night. When I woke up this morning, the computer was somehow completely dead and did not show the no power sign. So I plugged it in and I heard the fans keep starting is if it’s trying to start up. That lasted for 2 seconds, then there was a pause, and then kept happening over and over. Is there any way I can fix it myself? Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hold down the POWER button for 10 seconds to turn it off. Sounds like you might need to do a SMC reset: https://support.apple.com/en-ca/HT201295
Esta resposta foi útil?
Pontuação 0
yes try SMC reset, if you cant get that far Make sure your charger is good!
i’ve had multiple customers come in thinking machine was dead and it was actually their charger or battery.
Watch the light on the charger when the computer tries to boot up. Is it turning off with the computer? if so try another charger.
Pontuação 0
Adicionar a sua resposta
Tim Nguyen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 127
