Ir para o conteúdo principal
Sixth generation of the iPad, released in March 2018. Available in Wi-Fi and LTE with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Will not charge IPAD
I tried switching power cords but it still will not charge. I even turned it off and powered it on by plugging in a power source, so I know the power receptacle is working. My battery is my next option. So the question is, how do I get the battery to Hawaii?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
What he said ^^ bring it to a shop with a tristar tester and they will be able to tell you which of the three it is.
Esta resposta foi útil?
Pontuação 0
If you have used non-Apple cables, you may have damaged the charging portion of your board.
Even if the battery is bad, the iPad should power on with the cable connected which leads me to think it’s either your cable (that’s gone bad), the port is damaged some how (you need to look at the pins), or the charging chip on the board is gone.
Pontuação 0
Adicionar a sua resposta
bgaralde será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 129
