Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
micro sd card reader not working even after replacement
my micro sd card reader wasnt reading sd cards. so i purchased a replacement and repair kit from this website. followed directions and it still doesnt work idk what could be the issue but nintendo online repair is closed still and im just really annoyed things just cant work.
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
3 respostas
Pergunta mais útil
Same thing as I had for 2 years, for me it was that you need to make sure the connecter is fully pushed in. If it still doesn’t work it may be a faulty socket on the board (don’t quote me on that).
Esta resposta foi útil?
Pontuação 3
I was in the same situation. After closer inspection, my socket was bad. I had missing pins. So I had someone replace it for me and it started working again. Replacing the socket requires micro-soldering, beyond my skills.
Pontuação 2
1 comentário:
I'm in the same situation as you who fixed yours and how much did it cost
por
I am also in the same situation. I did notice that while the switch is on, I can get the switch to detect the replacement reader if I press down on the connector at a certain angle. But I need a more permanent solution. I can’t be playing with the back open like that.
Pontuação 0
Adicionar a sua resposta
Luke Priore será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 47
Ao todo: 2,090
