iPhone 11 REBOOT LOOP - THERMALMONITORD
Dear all,
I have some trouble with my iphone 11, this one reboot 2 or 3 minutes after starting. If i don’t use it after the starting, this one doesn’t reboot…. (I have replace the rear glass this one worked fine before replacement)
I try to :
Restore and Update iOS : No result !
Try to disconnect all accessoiries on the logic board : No result !
When i go to the log files, it look like one of the sensor is missing and make the phone reboot !
reason" : "(1 monitored services unresponsive): checkin with service: thermalmonitord returned not alive with context:\nis_alive_func returned unhealthy : current 3fe3bfffffffffff, mask 1ffffffffffff, expected 1ffffffffffff. Missing sensor(s): mic2 \nno successful checkins since wake (120 seconds ago)",
Do you know where is the sensor ? « MIC2 » Wich flex need to be replace ?
If you want i can share you the log files.
Thanks in advance,
Best regards
Esta é uma boa pergunta?
5 comentários
I have same issue .Replaced power flex checked the microphone, it is working fine but mobile restarts after 120 seconds.Did your problem solved after changing lighting connector ?
por Mubasher Khan
I had this issue the only way to fix it is to replace it with an original cable from another phone, these part replacements you use from China won’t work. Depending on the error you either need to replace the power button/flash light flex or the charging port
por Glue Tech
Thanks man , I had the same log " Missing sensor(s): mic2 \nno successful checkins since wake (120 seconds ago) " I used china power button /flash/mic flex and issue is not resolved yet.I think that would be the issue in my case.
por Mubasher Khan
Replaced power button flex cable and all goes well and my error was: Missing sensor(s): mic2
por Mirko Cavasino
Mirko Cavasino did you ever resolve this problem ?
por Riyadh
