Ir para o conteúdo principal
Repair guides and information for the Nintendo Switch Joy-Con controllers.
167 Perguntas Visualizar todos
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
Esta é uma boa pergunta?
Pontuação 9
Adicionar um comentário
3 respostas
Pergunta mais útil
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
Esta resposta foi útil?
Pontuação 2
Did you try updating controllers? It worked for me
Pontuação 2
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
Pontuação 2
Adicionar a sua resposta
Falling Rose será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 107
Duração total: 5,747
