Ir para o conteúdo principal
when uploading OS progress bar stops at 100% for hours
I am trying to revive my 2007 Macbook Pro so I replaced the broken HDD with a new Kingston SSD. However, when I try to install El Capitan the progress bar loads to 100% and will stay there for hours. I have left it at 100% for about 13 hours.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Are you trying to upload El Capitan via DVD? Is your DVD or CD drive damaged?
Esta resposta foi útil?
Pontuação 0
A common issue with this series is a replacement HDD/SSD drives data rate spec exceeds what this system can support. This hang condition you are encountering sound like the replacement drive is not the correct drive or it’s jumper setting is incorrectly set.
Here’s this series spec: 17” MacBook Pro Core 2 Duo
Note the Storage Interface: line this series interface is only designed to support 1.5Gbps (SATA I)
Pontuação 0
Adicionar a sua resposta
Erik Carroll será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 39
