Ir para o conteúdo principal
Model M8541 / 5 or 10 GB hard drive / scroll wheel physically turns
29 Perguntas Visualizar todos
Can I put a flash drive on it?
Hello there.
I would like to know if it is possible to change the hard drive for a flash memory/SD Card.
I haven’t seen much information on the Internet and I have even seen people saying it is not possible.
I found this video where a flash drive is being used, but it doesn’t give much information, so I don’t even know if it is trustworthy.
Thanks in advanced.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I have read that you need to make a disk image of the original hard drive, and copy that to your flash memory. However, I’ve only heard of one person doing this, so there is no guarantee that it will work.
If you need to replace the hard drive, I would suggest to get a new hard drive for it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
JV Lobo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 83
