Ir para o conteúdo principal
Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
37 Perguntas Visualizar todos
Lenvo Y50-70 Charging Port wiring on mother board
Hi,
My lenovo y50-70 charging port wires detached from mother board , I have to solder it again but there is no wiring connection indication on motherboard . Anyone can please share how to solder these wires on mother board ? which wire for which point?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
This may help:
http://www.s-manuals.com/notebook/lenovo...
Have you tried taking a high resolution photo of the motherboard or using a magnifying glass or loupe to look closely at the board. You should be able to see where the connections were. A broken wire end or some other disturbance at the solder pad..
Esta resposta foi útil?
Pontuação 2
2 comentários:
I checked and came to that charging ics had burnt and I am unable to see ics number as well. Is there anyway to get charging ic numbers?
por
Hi @Muddaser Talal
You should be able to find it if you search through the schematics I pointed to you above.
por
Adicionar a sua resposta
Muddaser Talal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 256
