Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
iMac 20" A1224 dark screen with 9 beeps
I have gone through the previous messages about this issue:
3 short + 3 longer + 3 short beeps means EFI ROM checksum failed. I downloaded and created Firmware restoration CD 1.6 for iMac7,1 from Apple support.
Turned power on and iMac sucked in the CD and ejected after 1 minute and started beeping cycles again.
Questions:
  1. I burned the CD on Windows with PowerISO. Should I try burn the CD on Mac instead?
  2. It seem doing something with the CD. Or it's hardware issues with the ROM or board that firmware refresh won't fix?
Any feedback welcome. Thanks.
ps. I remove the screen and couldn’t see any bad connection and also replaced the lithium battery too.
Esta é uma boa pergunta?
Pontuação 1
4 comentários
I have the same problem and I was unable to find the 1.6 Restoration CD (link @apple gives not available error).
Please where did you find the iso?
por
Hi! I have the same problem. I try to find Restoration CD 1.6, but on an Apple's website, the link is dead. Dropped the entire internet in search of a disc! I've been looking for three weeks! Maybe you still have an image of this disk?
por
Do you have the link for the firmware restore cd 1.6 the Apple site link is dead I also have this issue. I have access to another Mac to burn the image to cd
por
You'll need to contact Apple Support to get it.
Point to the Firmware Restoration CD 1.6 page so they can see someone messed up the file access.
por
Adicionar um comentário
2 respostas
Solução escolhida
Ok thanks I’ve managed to fix it. I stripped the machine down this morning. It would appear the CMOS battery was loose. The plastic that holds it in place has failed so replaced it with a new battery and used good old hot melt glue to hold the battery in place. Switched her on and heard the lovely Mac chime again. Put her all back together she’s working a charm. Thanks for your suggestions.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Sounds like the iMac didn’t like the created CD. That could be because making it on a windows system Vs Mac. It’s also possible the format of the CD was not correct.
Can you make a fresh one on another mac system?
Pontuação 1
Adicionar a sua resposta
Sunyao será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 520
