Controller not reading battery correctly?
I have two controllers, let’s call them Controller A and B.
Controller A is perfectly fine, it charges as normal. Battery A is fully charged.
Controller B shows a yellow light and can turn on when the micro-USB is inserted HOWEVER it immediately turns off as soon as I remove the micro-USB cable.
Today I put Battery B into Controller A and PS4 says the battery is dead. Currently charging the controller and Battery B IS recharging.
However after placing Battery A into Controller B, the Controller stays on for like 2 seconds then turns off. PS4 says Dualshock is disconnected, charge the battery. I’ve placed the Controller on charge but after 5 minutes I removed it and the controller won’t turn on. Just to reiterate Battery A is fully charged.
So what’s the issue with Controller B and how can I fix it?
Esta é uma boa pergunta?
