Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
Microphone not functioning after replacement.
So this year I've come across an iPhone 7 Plus that has the iOS 13.5.1 and the client says that the microphone has stopped working around November-December of 2019. I replaced the iPhone 7 Plus Charging Dock Flex Cable and the phone still behaves the same. The Bluetooth headsets/speakers that I connect it to will allow the phone to record and hear sound fine but only through the phone or voice memo app. The voice memo app won't even attempt to record sound without a BT connected. I've tried connecting a lightning headset to the phone and still nothing. The video or ANY app that uses video will Not record any sound however , Bluetooth or not. The speaker that is connected to the Charging Dock Flex Cable has ALWAYS worked, the charging has always worked and so after replacing the flex cable this leads me to believe that this was a software/firmware issue. I am considering jailbreaking to revert to an older iOS (maybe before November 2019) but before I do, I would like to exhaust all options. I have never jailbroken a phone before and am trying to be cautious. What are your thoughts on this issue if you please?
It should be noted that the phone went back to behaving with the same dysfunction after the part was swapped.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
So it turns out it was the logic board and I am still in the middle of replacing it. I ordered a locked one by mistake and am in the middle of trying to unlock/wipe clean.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Can Siri hear you? If not I would suspect you have the classic Audio IC problem for the 7 series. If this is the case an earlier IOS will not fix the problem.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Siri cannot hear me without BT. So now I have another issue...
So I replaced the logic board and I find a cheap one on eBay for less than $40. Come to find out, it is locked. I have tried YouTube/Googling and have yet to find a method that will allow me to get past the required lock screen which displays the limited email address. I get it into recovery mode > Restore and Update > Lock Screen. Other methods require me to manually enter DNS addresses but like I said, nothing.
Help!!!
por
Adicionar a sua resposta
boxerbc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 507
