Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1200 Perguntas Visualizar todos
Do you have a guide for replacing iPhone X wifi antenna? (Model A1865)
Recently dropped, damaged my screen. I replaced my screen but also noticed the wifi hasn’t worked since the drop. The settings will say it’s connected but the phone is not really connected to wifi. All of my other devices are functioning fine with wifi. How do I really know if a new wifi antenna needs replacing?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
You can check the connection, it's under the front camera next to the rear camera on the motherboard. You will to unhook the top section of the battery and lift it up enough to remove the cables to the front camera. You can check the connection to the wifi antenna and if necessary change it. I have pictures of the parts that you can pick up on ifixit website. You should be able to find videos on ifixit and YouTube that will show you how to change it.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
No Wi-Fi is a pain with the iPhone X. The rule I follow is if the Wi-Fi is greyed out it will be a logic board problem. If it is connected it will more than likely be a parts problem so a replacement antenna might be the fix. There will be YouTube videos on the replacement if you cannot find a guide here. But it would be best to check your connections first.
Pontuação 3
1 comentário:
@imicrosoldering - Technically the case holds the antennas, the metal bands are called a bus bar and the coax cables are wave guides which interconnect the logic board to them. Just saying ;-}
por
Adicionar a sua resposta
Benjamin Cave será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 566
