Laurastar Premium S3 problems with steam
The iron base heats up and the boiler generates steam. So you can iron with the appliance.
But on a regular basis the steam function drops out.
Does anyone have an idea how you can make this or what the causes are?
With best regards
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi stijnvandun, I just started looking into an Evolution ii model 725 for someone due to what I suspect is a failed cartridge heater assembly in the iron. Although these are different models and different problems, the working principles are very similar if not the same. Could you provide any more information? Do you notice anything different when the steam function drops? Can you still hear any clicking of relays? Do any switches feel loose? Noises might be our best source of diagnostic information right now, but absolutely any and every piece helps. Even the slightest change(s) can help us pinpoint and solve this problem!
por
Adicionar um comentário
