Ir para o conteúdo principal
TI-84 Plus calculator support.
Is there any way to remove the board from the case?
my lcd is dead and i need to remove the board.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Step 1:
To begin with, you can follow this guide for the TI-84 PLUS Silver Edition of how to get the backplate off, ignore step 1 and 2 in the guide (don’t know if you can do it on your device and it’s not necessary from what I can see). TI-84 Plus Silver Edition Motherboard and Screen Replacement
Step 2 - Choose alternative A or B:
A: When you have got the backplate off and it’s looking to be the same as in the guide, then you should be able to follow the guide. Keep a bit extra attention for every step so it’s looking the same as yours, the guide isn’t for the exact same model as the one you have.
B: If it doesn’t look the same, then add a picture of how it looks in your question if you don’t find how to do it yourself. Adicionar imagens a uma pergunta já existente
Imagem de TI-84 Plus Silver Edition Motherboard and Screen
Guia
Nível de dificuldade:
Moderado
5 - 15 minutes
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Zack Polaski será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 179
