Ir para o conteúdo principal
Lançado em 26 de outubro de 2018. Modelos A1984, A2105, A2106, A2108. Disponível como GSM ou CDMA / eSIM, nano-SIM ou SIM dual / 64, 128 ou 256 GB / Preto, Branco, Azul, Amarelo, Coral ou Vermelho. (Pronuncia-se "iPhone 10 R.")
Screen Unresponsive, Ghost Touch
My daughter's iPhone XR started developing some weird symptoms where without input, it opens up apps, scrolls between screens, etc... After some googling, found that this is referred to as ghost touch or something. Couldn't find what the fix is to this problem though.
I tried resetting the iPhone to factory settings, even tried doing a reset/restore in DFU mode, to no avail. I wanna say this is maybe a hardware issue with the display (digitizer/glass) more so than a software issue. She had a case on it from day 1 but did drop it a few times, and even had a small crack on the screen towards one corner, not too bad though.
This being the case, I'm willing to replace the display myself, but before I shell out $100 on a new one, I wanted to see if anybody else experienced this issue and if so, did replacing the display fix the problem?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
I'm having this exact same issue. Phone is pretty much useless right now. Keeps swiping constantly between apps and clicking whatever is at the bottom of the screen. Did you ever replace the screen, and if so did it fix the issue?
por
Replacing the display assembly fixed the problem.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You can buy a good quality screen for a iPhone XR for around 50 dollars. My guess is the dropping and possibly the crack can cause these issues. I would try replacing the screen.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yes a new screen should fix the problem.
por
A new screen has not fixed my issue
Pontuação 0
Adicionar a sua resposta
Jose será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 1,857
