Ir para o conteúdo principal
Screen acting up after replacement
Switched out the screen on my iPhone 6 plus and now it's doing some wired stuff it's touch is not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Clean the flex connector and reseat the connectors again and make sure they seated properly.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I have tried that a couple of times and it don't seem to work
por
@Mike Olesen Leslie is right. This is a touch connector problem. Sometimes the touch connector becomes bent if it is not aligned properly. You might have to straighten it out. After connecting check that it is sitting flush by tilting the phone up.
por
Adicionar a sua resposta
Mike Olesen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 127
