Ir para o conteúdo principal
2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
85 Perguntas Visualizar todos
MacMini won’t boot with a SSD on the Thunderbolt3 port
I bought a Crucial 1 TB SSD and plugged it into my Thunderbolt 3 port.
And when plugged in, my mac (2018 Mac Mini with upto date OS) it just won’t start. With verbose mode, no text appears on screen: just the apple logo.
Note: macOS boots from the internal SSD, this external SSD is just a plain storage unit.
What I’ve tried :
  • Some have speculated it could be related to the eGPU, but unplugging the eGPU doesn’t solve anything.
  • I tried removing the T2 security “Boot from SSD” - no change
  • I’ve checked the boot order, it’s set to the internal SDD
  • I have 3 HDD on the USB ports that work just fine
So far, the only solution is to unplug the SDD, and plug it back (which is not really a solution, is it ?)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
There are a couple of issues trying to boot from an external drive besides the systems T2 security controls.
First the drive needs to be formatted with GUID and the drive needs to be setup with APFS not HFS+ as macOS Mojave and newer requires it.
The next is the version of macOS needs to be what the system requires so you do need to make sure its setup with macOS Mojave or newer.
When you start your system you do need to enable the Startup Manager to select the drive you want to boot up pressing the Option (⌥) key.
Reference: Mac startup key combinations
Esta resposta foi útil?
Pontuação 0
2 comentários:
as I said in the original message :
The SSD prevents the Mac from booting… the OS  is installed on the internal drive
por
The way you wrote your question was unclear what the goal was. It sounded like you wanted to boot up under the external I tried removing the T2 security “Boot from SSD”
Let's do this with just the monitor and the external SSD plugged in does the system boot up at all? If it does then the power draw of the drive (the collective pull for power across all of the devices) is to great at the point of boot up. Using a powered hub might make a difference here!
por
Adicionar a sua resposta
Étienne R será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 699
