Ir para o conteúdo principal
The second generation (chassis model L30) was an American market-only version, again styled by Nissan's California design center under Doug Wilson through 1994 (design freeze in 1995).
8 Perguntas Visualizar todos
Will turn over no start
I have a 1999 Nissan Altima Gxe 2.4L engine. The crank will turn over but want start. Have already changed the spark plugs, spark plug wires, distributor cap and rotor. I also just changed the valve cover gasket cause it was leaking and changed oil and filter. It wouldn't start before i did the tune up and valve cover gasket change.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Yes. Changed spark plugs, spark plug wires, distributor cap and rotor. It wouldn't start before I did the tuneup on it. Would turn over but not start
por
Adicionar um comentário
2 respostas
Did you check for spark and fuel? Did you check the timing belt and make sure it was on time? First steps before you do anything else.
Update (06/24/2020)
You need to see if it has spark and fuel pressure. You need to check and see if the timing belt is broken. There are multiple reasons a car will not start.
Esta resposta foi útil?
Pontuação 0
2 comentários:
How do you check the fuel pressure
por
My advice is take it to a shop
por
Are you sure the car doesn't have an inertia cut-out, which has tripped (they are designed to turn the engine off in case of accident)? I am not familiar with this car specifically, but the switches are sometimes found in the vicinity of the spare wheel well.
Pontuação 0
Adicionar a sua resposta
Sean Harkins será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 436
