Is there a way to check if my engine is getting fuel?
I can hear the fuel pump running but I’m not sure if I’m getting fuel to my motor. How do I check
Esta é uma boa pergunta?
It might have a fuel pressure test port in the line. If it doesn't you will have to unhook the line and put a fuel gauge in the line. Shops carry those sets but they run in the hundreds of dollars. If it has a test port you should be able to rent one from autozone, o'Reilly's, etc. You should also verify that you have spark.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 294
