Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
Pergunta encerrada
Home button not working after replacing?
My iphone was water damaged and the home button stopped working so ive replaced it and it still doesnt work. What else could it be? Ive replaced it with 3 different ribbons now and nothing!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Test to make sure that it is the home button that is the problem and not the docking connector assembly.
To do this, open up the (turned off) phone without disconnecting the three ribbon cables. Turn on the phone. Short the two contact pads on the top of the docking connector to simulate operating the home button.
If the simulated home button works, look at the connecting feet between the screen assembly and the docking assembly. If it doesn't, look into replacing the docking assembly.
Reading your description, I would guess that the docking assembly has been damaged.
Good luck!!
Esta resposta foi útil?
Pontuação 0
1 comentário:
Also, it is very easy to check Home Button Flex function whether installed in iPhone or not. Check electrical continuity when you push or squeeze the button. Pushing the button completes the circuit. If the Home Button functions and the two contacts are in good shape you do not need to replace the Flex.
por
Most probably a corroded dock connector. Try replacing it
Pontuação 0
Yes check connector, if you need replacing it and have problem, let me know.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,191
