Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Won't turn on, no light, fan not running.
I've got a Black 2.4 GHz A1181 MacBook.
Its bezel, keyboard and battery had been previously replaced. It's been left a few years in a drawer and now doesn't turn on at all!
Battery doesn't charge, light at the front doesn't light up and the fan does not spin at all.
When mains is plugged in the charger LED goes from Green to Amber meaning that its trying to charge the battery, but it doesn't.
Any advice on what to try?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
The best you can do is try a fresh battery MacBook Battery
Imagem de Replace a 4900-5200 mAh battery compatible with MacBook model A1185. Part #661-3958, 661-4254, 661-4413.
Produto
MacBook Battery
$79.99
Esta resposta foi útil?
Pontuação 0
Have you tried simply removing the battery and just running it off the adapter? I’ve gotten some A1181s to power on this way.
Pontuação 0
1 comentário:
Yep doesn't work, the only way to get it to work is to put a screwdriver or flat piece of metal over the power connectors to jump start it.
por
Adicionar a sua resposta
brandon miles será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 57
