Ir para o conteúdo principal
Released in July of 2010. Identified by model number Vaio VPCEA3C5E.
4 Perguntas Visualizar todos
Display black. Start chime works. Does not connect to external monitor
Hi
The display of my old workhorse is pitch black. It was dim 2 days ago and I could see a few things but now it has gone completely black. I tried connecting to an external monitor using VGA display but it does not connect. Someone suggested I clean the RAMs pins with a soft tissue which I did but that didn’t fix things. My universities tech support suggested that I replace the LCD display but why wouldn’t it connect to an external monitor even if the LCD is bust. What could be wrong?
Thanks,
Abhishek
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
To connect to external monitor you have to press “windows key “ +“p”
Multiple times until it connects
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your answer. It now connects to the external display. So clearly the display is broken. Is it possible to repair it or should I just go ahead and change it!
best,
por
Adicionar a sua resposta
Abhishek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 115
