My Optical Drive ejects discs after I insert them.
The optical drive of my iBook G4 ejects discs after inserting them. It can't play discs.
Esta é uma boa pergunta?
This may help: ZAP the PRAM - hold down the option & apple keys also the P & R keys and restart. Continue hold the keys till you have heard three bongs. Test the drive again. If it doesn't work I would replace it. Take the battery out see if there is a tag inside that tells us exactly which iBook you have. I will then be able to direct you to where to get a replacement drive and how to put it in.
Esta resposta foi útil?
This might help: http://www.ifixit.com/Info/ID-your-Mac
Ok, I have an iBook G4 computer with 1.5 GB of RAM and a processor of 1.33 GHZ. Mac OS X Leopard 10.5.8. 12 Inches. I live in El Salvador, Central America.
Help!!!
Here's a Combo drive that will work for you: [produto vinculado ausente ou desativado: IF183-028] The superdrive, in my opinion is much to high.
Here's how to install it: iBook G4 12" 1.33 GHz Optical Drive Replacement
Try cleaning the drive with an optical drive cleaning disk
Chris is right. Sometimes just a lens cleaning restore the drive functionality. I perfer a manual lens cleaning with isoprophylic alcohol but I understand that many people wont open the machine just to clean the optical the drive.
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 47
Duração total: 6,267
2 comentários
Does it eject all disks or just burned disks? CD's or DVD's? All brands of disks, original disks say from Apple?
por mayer
The iBook G4 I am talking about ejects any discs that is inserted in it, it is to say: blank discs, burned disc, used discs, cleaned discs, CD, DVD, and also the installation discs.
So I do not know what to do, I do not know if damaged at all or can be repared at some way.
HELP!!!
por Samuel
