Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
Automatic shutdown when there's no external monitor
My MacBook Pro with intel integrated graphics shuts down randomly whenever it is not connected to an external monitor. When connected, either through thunderbolt adapters or HDMI cable, it will run indefinitely without shutting down. However, when I unplug the external monitors it will shutdown within seconds to minutes. If I stream a video while there’s no display connected, I can sometimes get an hour or two of uptime before it shuts down. Does anybody have any clue what could be happening? I’ve reformatted and clean installed Catalina, flashed the NVRAM and SMC, and cleaned the fans and fins.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If the board number is 820-3332 the problem will be bad solder on the U8900 chip. The chip will have to be re-soldered. This is a common fault on this model. The board number will be under the SSD. I would suggest getting a repair shop to do the repair.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
tjleps será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 251
