Ir para o conteúdo principal
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
20 Perguntas Visualizar todos
Schematics diagram of the circuit board
I’m trying to fix a broken Fujifilm Instax Mini 8 and there is something wrong with the board. I’m suspecting a resistor went bad, but it’s a super small SMD resistor and I’m not able to read its value. I was trying to find schematics to find out this information but I didn’t have any luck :(
Are they available somewhere?
The resistor is R43 on the board, next to the microcontroller:
Thanks
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hi.. Have u able to repair? On my camera all leds are flashing. Do u have the same problem?
por
Adicionar um comentário
1 resposta
Just contacted Customer support, I’ll get back to you on that, in the mean time I’ll look around for the resistor
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks a lot, Carter!!
por
Adicionar a sua resposta
JV Lobo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 535
