Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
Rear back glass replacement
I’m looking for rear back glass for iPhone X to replace my broken glanss.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Here is the Part, Really difficult task (by hand):
[produto vinculado ausente ou desativado: IF377-008]
You can buy the Complete housing and finish a good work.
iPhone X OEM Rear Case
Imagem de Replace a broken or scratched rear glass panel, dented or damaged aluminum frame, or scratched lens cover on an iPhone X with this used OEM rear case.
Produto
$59.99
Esta resposta foi útil?
Pontuação 0
You have a few options. You can pull the phone apart and freeze the glass and chip it off. Or pull it apart and heat it ut up and chip the glass off. You can take it to a repair shop and they can change it by using a laser to vaporize the glue. Or you or a repair shop and replace the rear case with the glass already installed. You have 2 options with the rear case. You can get one with just the power and volume buttons and the wireless charging coil or item two you can buy a rear case with everything installed except for the cameras and the battery and also the motherboard. I would look at all of the options and see if it's cost effective and if your up to the skill and time involved. I currently buy the rear case with all of the parts installed. It's not that much different in price and I can't afford the laser machine yet.
Pontuação 0
Adicionar a sua resposta
Khaled Alsuwaidi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 15
Ao todo: 1,286
