Ir para o conteúdo principal
Home Bread Maker released in the late 80's. This Bread machine has a standard size vertical bread pan and multiple settings to making a variety of doughs and breads. Identified by model number HB-B102.
Why does motor not run and paddle not turn
Started HB-B101. Paddle turned briefly, then quit. Started couple more times, but paddle didn’t turn. Machine completes cycle, lights show progress through cycle, element heats, but motor doesn’t even attempt to start (no humming). Found paddle shaft seized. Removed, lubed, and now fine. Motor test: motor removed, connected to power. Humms, but doesn’t turn. Slight spin of shaft and motor runs perfectly. Capacitor: connected to power for 5 seconds. Removed from power, touched screwdriver to one lead, then other lead…crack/spark/discharge. Connected both motor and capacitor to power (together). Motor still humms and needs slight spin to begin running. But…during seemingly normal cycle no humming, no nothing. Did something “blow” during the first attempt above and now is not sending power to the motor?" Any help appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sorry, sounds as though your motor is shot. Time for a new breadmaker I think.:-)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
George será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 572
