Ir para o conteúdo principal
Released June 2014, identified by model number B051.
Leather covering on my ear cushion is peeling off--do I replace it?
I’ve been having a slight problem lately where the leather covering the foam on the ear cushion is starting to peel out. I used to be able to wedge it back into place with my fingernail, but I think I’ll probably have to find a more permanent answer soon. Can I just glue it back into place, or is that bad for the earphones? Should I replace the whole ear pad?
Also, would the answer be different if it was just a Solo rather than Solo2? The headphones are actually Solo, but not the HD version or anything. I don’t think there’s really a huge difference between the two.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Here’s a video on how to replace them:
https://www.youtube.com/watch?v=CCzrrgwF...
Several companies make replacement pads.
Here’s cheap ones from Amazon
https://www.amazon.com/Replacement-Earpa...
Here are better ones:
https://wickedcushions.com/products/beat...
Esta resposta foi útil?
Pontuação 2
1 comentário:
thanks, I'll try that out!
por
Glue near audio equipment isn’t the best idea, if you can replace it it’s probably a good idea. I’m not an expert on beats headphones and there may be better advice so I’d wait to see any more advice from others.
Hope this helps, Nick
Pontuação 1
Adicionar a sua resposta
Maya N será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 69
Ao todo: 9,650
