Ir para o conteúdo principal
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
battery change screen removal
I have a ZAGG - Invisible Shield HD Glass Screen Protector on my surface pro. Do I need to remove it before i disassemble it or will it help protect the screen while im removing it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you the battery swollen up and the screen on the bottom and both sides are free screen is only stuck by the top
por
Adicionar um comentário
1 resposta
Solução escolhida
In my personal experience I always remove screen protectors because they tend to absorb more heat thus requiring more time and heat to remove the screen. Be very careful when you work on these things. Surface tablets are picky and are a pain to work on.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I totally agree. I always remove the screen protectors before I proceed.
por
Adicionar a sua resposta
Lucky será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 28
Ao todo: 227
