Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
Screen is irresponsive to touch
Hello
my iPhone felt down ( very good one)
when I got it the screen was ok
when I try to unlock the screen through side button, it unlocks
but screen is irresponsive to touch
I can’t touch for like a one minute
after several trails of pushing the side button to open and close the screen finally it responds and then touch screen becomes perfect and fast until I lock the screen again
I tried to update the phone
force locking it , tried removing screen protectors
but nothing
but it seems like a hardware issue somehow because it started after the fall immediately
I called someone to fix it ( no apple store in my area) he suggested to replace the screen, and I don’t think I will need to change the screen , As it looks intact and eventually responds very good
maybe just to get it removed and placed again ?!
now few times a day the problem is not there
but most of time it’s there
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
You most likely dislodged the touch connector. Easy fix, but you will need to tools to open the phone, disconnect the battery connector (always do this first), and then disconnect and reconnect the screen connector tabs. Here is the iFixit guide: Substituição da tela do iPhone X
Complete up to step 20 then do everything in reverse.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Sounds good
I will try it
Thank you
por
Pergunta mais útil
Sounds like a bad screen to me. I’m guessing you’ve tried reseating the screen connections?
Pontuação 3
1 comentário:
Thank you for your replay
No I haven’t reseat the screen connections , how ?
por
Had the same issue... reboot using this method. Fixed it.
How To Hard Reset / Force Restart iPhone X:
Step 1: Press the Volume Up button and then release, followed quickly by pressing and releasing the Volume Down button.
Step 2: Now quickly press and hold the Side button until you see the device’s screen turn off, followed by the Apple logo showing up on the device.
Step 3: Once the Apple logo appears on the screen, release the Side button to complete the force restart cycle.
Pontuação 0
2 comentários:
I tried it, did not work unfortunately
Thanks though
por
@s.s.h-1991 My pleasure
por
Adicionar a sua resposta
s.s.h-1991 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 178
