Ir para o conteúdo principal
On MacBook Pro having LCD screen issues lines no pic .
i recevied a mac book pro from Ebay. the seller told me that when you plug up an external monitor , the graphics work. but when you use the internal screen you get lines and no graphics. And black spots appear after a few mintues . i check all the connections related to the monitor and all was good. Can you help me?
Esta é uma boa pergunta?
Pontuação -1
4 comentários
We need more information. Are you telling us what the seller described, or what you have witnessed? Have you verified that it works when connected to an external display?
por
Please give us the lasy three figures of your serial number
por
Hello Mayer, the last three figures are VWW
por
to rdklinc: when i connected it to an external monitor, it worked, but with a blank screen . Also when he gave it to me it had no screws around the base, or the monitor itself .
por
Adicionar um comentário
2 respostas
Pergunta mais útil
This is not the Nvidia issue as your Book has a Radeon GPU.
Apple MacBook Pro "Core Duo" 2.0 15" Specs
Identifiers: MacBook Pro - MA464LL/A* - MacBookPro1,1 - A1150 - N/A
Since the seller did not provide a product as described (i.e., the external monitor fails to work), I would return it. It's probably a money pit. If it has no external or water damage, you can get it fixed by Apple for a "flat rate fee" of $280 plus postage.
Esta resposta foi útil?
Pontuação 1
I understand that this is a graphics card problem
Pontuação 0
2 comentários:
Will a mac book pro a1150 work if connected to a windows pc compatible monitor ?
por
Yes it will with a Mac or a PC
por
Adicionar a sua resposta
Alvin R Brown será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 657
