Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
iPhone SE screen separating
My iPhone’s screen in separating on the top, it moves whenever I tap the screen. Could this be due to battery swelling (I read it’s a problem on the iPhone 5, but also SE?) or has the screen come loose somehow? The screen itself works fine, no other problems there. What could cause this and how can I figure it out?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It's a problem with the batteries swelling and causing the screen to push out. You need to open the screen and verify that is the problem. Be careful when you open the screen, the home button cable is there and you need to open it slowly and not past about a third open and unhook the cable.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
FRoYo45 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 276
