Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
weird iPhone 8 power problem
my iphone 8 has a weird power problem where it won’t turn on with the side button or a charger plugged in but i can put in dfu mode and itunes recognizes it but it won’t restore because it never reconnects after itunes kicks it out of dfu mode. is this fixable cause i’m stumped
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This sounds like a NAND or CPU problem. When it exits out of DFU mode it is not getting instructions on what to do next that’s why it never reconnects to iTunes. The only thing I would try is replacing the battery as DFU mode doesn’t use much power so when it switches from that to normal mode if the battery was faulty and couldn’t supply enough amps it would shut down.
Esta resposta foi útil?
Pontuação 1
4 comentários:
letting it die and then plugging it in caused the low battery symbol to come on the screen followed by the apple logo which disappeared after a few seconds and i was back to the original issue
por
I would definitely replace the battery
por
So the battery may be bad
por
Yes. You need to rule that out first.
por
Adicionar a sua resposta
Cheap gamer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 72
