Ir para o conteúdo principal
Um e-reader com tela sensível ao toque da Amazon, com botões silenciosos para virar páginas e luz de fundo com ajuste automático, lançado em 21 de outubro de 2014.
Water Damage- Touch Screen Unresponsive
Hello :) I left my Kindle Voyage in the rain (devastating)! After a few days in rice I plugged it in and turned it on. To my surprise- it turned on and lit up. However, the touch screen isn’t working. The side buttons still vibrate and work, I just can’t select a book or anything because the touch won’t work. Is this something that is fixable? Or is it gone forever? Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello,
if its water damage, you have to check with the professional technician, it might be due to water still exists or damage the components inside as well. they will able to clean and check with isopropyl alcohol or ultrasonic cleaner.
if you are able to open, please attach the picture.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ashley Edwards será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 609
