Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
Apple LED Cinema Display "27" and Temperature
Hi guys,
I recently bought an Apple LED Cinema display and had some issues with it.
Sometimes, the screen won’t turn on, it will stay black for hours but, the speakers and the USB work fine.
I’ve been trying some tests on it and found that when I sleep with my window open at night, the screen will not turn on for hours when I try to turn on him the morning. But every time I sleep with the window closed, the screen will automatically turn on, and won’t have a black screen.
So my question, is there something linked to the temperature of the room, or the display itself that keep him on black screen?
If yes, is there a piece that I could change to fix this problem?
Esta pergunta é pertinente?
Pontuação 0
8 comentários:
What is the system you are using it with? Mac Pro, MacBook Pro or iMac?
por
i am using the display for my Windows 10 computer
por
@bobtaro - Are you able to test the display with a Mac system?
por
@danj no, i don't have any MAC system
por
I think you'll need to find a friend with one to test your display out with.
por
Mostrar mais 3 comentários
Adicionar um comentário
2 respostas
Did you update?
About the 27-inch LED Cinema Display Software Update 1.0
Esta resposta foi útil?
Pontuação 0
1 dos comentários:
i don't have a mac, so i can't update it
por
It appears the logic board will need repairs or just replacing it (logic board P/N 661-5544). Given the age of the display, it’s likely a weak cap or cold solder joint is the issue.
See if you can find a set of the LED Cinema Display (27-inch) Schematics & Boardview to help you isolate the area of theologic board that needs service.
Using the Mac you can now check the displays firmware is upto date: LED Cinema Display Software Update 1.1 This addresses a speaker issue it had.
Pontuação 0
Adicionar a sua resposta
Filip será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 476
