Ir para o conteúdo principal
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Perguntas Visualizar todos
What causes these moving horizontal lines on display?
I’m assuming the issue is caused by a damaged display and that I would need to replace the display assembly to resolve the issue, but I thought I would ask about it on here to see if it might be related to something more specific. Note that the horizontal lines in the pictures are separated into 6 columns of equal width, covering the width of the display, and they are constantly jiggling around. They are mostly pink and light blue / green. The right-most column of lines is less dense. Any advice is appreciated, thank you!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Yes, your display is damaged, more precisely the T-CON board has failed. This is the thin board held in the uppercase.
Most laptop displays have it within the lid. Apple decided to be different! They placed it into the uppercase in the worse location! It tends to cook!
Sadly, once damaged it is not repairable and Apple only sells the full assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 15" Touch Bar Late 2016 Screen Replacement
Imagem de MacBook Pro 15" Retina (Late 2016-2017) Display Assembly
Produto
$507.99
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Zach será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 523
