Ir para o conteúdo principal
The Samsung Galaxy Tab A 10.1 S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new “A” series.
Is there any difference between a sm-P580 and a sm-T580 display?
I’ve been watching some tutorials about a sm-P580 screen and LCD replacement, but almos all the information I’ve found is for the model sm-T580. Are this models screen and LCD compatible?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Yes, a LCD display is compatible with both types. But when it comes to display type, you have more things to consider.
(Take LCD and LED screens as an example)
As you try to make the best choice for your professional and personal monitor needs, consider what features are necessary and most important to improving your work space and/or your gaming space. In many cases, an LED monitor holds the advantage due to its longer lifespan, better picture quality, thinner design, fast response time and more environmentally friendly construction. These qualities offset the higher initial price point that might have you considering an LCD option.
Esta resposta foi útil?
Pontuação 1
Can I purchase the glass face for an SM T580 and install it in a P580?
Pontuação 0
Adicionar a sua resposta
Víctor Velazquez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,405
