Screw Diagram with Grounds?
In my brief foray into iPhone repair, I've come to realize how important making sure I replace every single little screw on my iPhone 4. Is there a diagram that exists or can someone create one, showing all the screws that ground certain components (such as the long screw at the top being necessary for wifi/GPS)?
That would help immensely as some money could be saved on parts when I know there is just a screw that needs to be in place in order for some components to function properly. I think this may be the case with my non-functional mic and crappy sounding speaker.
Thanks!
Esta é uma boa pergunta?
5 comentários
there should be a screw guide to print for disassembly of your phone, you might like to take notes from the guides which have notes about those screws. Take a look at the front display guide..it seems to have most screws listed.
por pollytintop
Not what I'm looking for but thanks for responding. I really need to know why my mic isnt working even though I've replaced my dock connector/microphone. I can only assume something's not making a connection and need to know ASAP. Not being able to make phone calls on my PHONE is not good...
por bgibson72
If you look at the guides like this one and check the instruction on the right side, each screw is described and should therefore help you with you task.
por oldturkey03
Again, they say nothing as to their dependencies. I was able to find at least one other person that was having the same issues and someone was knowledgeable enough to mention that the screw closest to the rear-facing camera that contacts the metal frame of the phone grounds the mic. In those guides, there are no notes mentioning this. I guess it's a secret...
por bgibson72
don't think it's a secret..you are on about the second mic that cancels out noise in calls (near camera) but it sounds like you're having trouble with the mouthpiece mic..I'm sure this has been dealt with, give us a bit of time and we'll link to that for you.
por pollytintop
