Ir para o conteúdo principal
O DualShock 4 CUH-ZCT2 foi anunciado em 2016 para substituir o controle CUH-ZCT1 lançado em 2013. Este controle é semelhante ao modelo anterior.
Ps4 controller O button not working
Hi just wondering if anyone can help me my ps4 controller O button not working yesterday i noticed when i pressed the O button nothing happens and after pressing the button 5 or 6 times it worked but now nothing everything else on the controller work's except the O button
Can anyone help me please
Thanks
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi Jamie!
I advise to open up the controller and clean it. Do not forget to clean the ribbon circuit board. And make sure it’s all seated as it should and connected.
If that won’t work, replace the ribbon circuit board, this should fix it.
If you order one, make sure it’s identical to the one which came out, there are a lot of models available and they are different!
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for your reply i have opened it and cleaned it no i will order a new ribbon for it and thank you or reminding me to check and make sure i order an identical one i would of just ordered the first one i see thank you
por Compartilhar
Your welcome! Good luck with the repair! Yes, you need to order the one which is identical of what you got now.
por Compartilhar
Adicionar a sua resposta
Jamie Edwards será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 8,761
