Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7 Touch ID Not Scanning/Spazzing Touch
I just did a battery replacement on an iPhone 7. Very clean, didn’t touch anything I didn’t need to, and was very gentile with the device. After putting together, it said Touch ID Not Available and the home button stopped working. So I took it apart again, disconnected the screen connectors, and then air blew the connectors. After doing this, the home button works and there is no “Touch ID Not Available” pop up. Yet when trying to read a fingerprint on the lock screen, the phone spazzes in and out of Reachability, and when entering the Touch ID settings in Touch ID and Passcode settings, it allows me to add a fingerprint and tells me that I am pressing too hard on the screen. I tried hard rebooting and even replacing the Taptic Engine but am at a total loss of what the issue could be. Here are pictures of everything that may help someone more knowledgeable than me help diagnose this issue.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You need to check the home button cable that goes from the screen to the motherboard. Check under some sort of magnification for a small tear in the flex, it usually occurs at the 90 degree bend.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I thought this too and checked it but didn’t notice anything wrong or torn? See the 3rd picture. Not saying that’s not the issue but I would hope that I would see something there if it was what was wrong
por
Some tears are microscopic I usually put them under a microscope to check but you will need to try another screen. If it is still the same it would point to the home button assembly.
por
Adicionar a sua resposta
Logan Davis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 108
